Last day i go on the highway
I have see my bike have like missfire star at 6000 rpm and finish at 7000 .....after 7000 rpm every thing is ok
Do you have any idee
Sorry for my bad english
On a cbr 600 f2 93
Probably need a valve job/shim kit. Timing issue? Timing maybe off. Valve work is probably one of the hardest jobs to tackle. Lots of good help on here to DIY. Shops charge about 400 to 500 dollars. Remember to start simple. Check spark plug/s, gap, sensors etc.
Because im in 1 and everything is ok i think he can a probleme with my spark plug coils pack because the engine is rebuild
Seriously sorry for my bad english i want show u more
Im not sure if on all my speed he do this probleme but i know ehen im in neutral possition on the way he dont do miss fire
And the engine was rebuilded
Alright i have do some test .... Every speed do this problem WHEN i turn the gaz in maximum but faster ......when i turn the gaz normaly its ok ......but when im in neutral position i can turn it fast and every thing is ok
I go see my spark soon but what is the best for my bike and whats the best gap i need ???
