1 - 9 of 9 Posts
It's connected to the Coolant reservoir bottle
Yes two lines from the Reservoir bottle 1 is the return line near the radiator cap and the other is the vacuum line. i pulled the vacuum line out from the motor side and now i can't seem to find where it goes.
The reservoir bottle has two hoses the long one is attached to the radiator feed the other is hooked up to the back side nipple look at your first illustration you will see what I am talking about
Is the #41 hose even connected to anything? If so where besides to the reservoir bottle
It's an over flow hose and extends from the reservoir bottle across the engine then ends up sliding thru the gap in the left side lower by the kick stand that is where the vent hose of the gas tank slides as well
Thank you Moeman i was freaking out i thought it connected to something.
I understand man it's my pleasure to help you sort it out :banger:
1 - 9 of 9 Posts
