1 - 8 of 8 Posts
The radiator on my bike is loose. I found that out when I was doing some work on it the other day. I don't have a pic at the moment but the screw on the top left of it was broken off in my accident. I haven't riden the bike since so I'm not sure how much it moves when I ride but I can wobble it pretty easy with my hand. So should I just go ahead and replace it or will it be fine loose?
Thanks in advance.
D
I'd go ahead and replace the bolt. Last thing you want is for the radiator to fully loosen up while riding. I'll find the bolt size for you real quick.
I think I would have to replace the entire radiator. The part of the radiator that the bold goes through is bent. I bent it back to try and put a screw in and I realized the the hole it goes in is not threaded so I don't know what the deal is with that.
As soon as I can find my camera in my messy ass room I will post some pics...
Here are the pics. They are not good but you can see that its bent out of place and the screw is missing.
Here's a pic of the other side which is fine.
D
Just get another screw and I'm sure it will be fine. Remove that horn while you're at it too. :p
I tried checking the size last night but couldn't get my hand in far enough with my fairings on, but I do believe it is M6 threaded. Could be M5 though. Stupid service manual doesn't say.
Thats what I was going to do, but the hole is not threaded. I couldn't get a pic of that tho.
1 - 8 of 8 Posts
