1 - 8 of 8 Posts
So, I was about to change air filter and I forgot to cover those 4 holes, doh :(
I unscrewed one screw that holds air filter and I think it slipped into on of thoes 4 holes.
How can I get that little bugger if it went down the tube?
Was thinking with some magnet on a thread or...?
I supose that screw can do some damage to machine if I don't get it out...
Go to your local auto parts store and pick up an expandable magnet.
If you didnt crack open the throttle it should be sitting up o top of the butterflys and a little magnet on a stick should do the trick. If you did open the throttle and it went in....get it out. It will destroy your engine, or at least break a piston or valve or both, proly bend a rod too.
if you dont want to spend the money, just get a long stick of some sort and tape some duct tape on the end so the sticky side is facing out. get a flashlight and go fishing, worked for me in the past
Bingo... got it!
Little stick with duct tape did the trick :)
Thanx all for advices and specially tjs46 for that l33t ghetto trick :icon_lol:
P.S. Next time those air intake holes will be properly covered for sure...
I wouldn't do that in his case. If he pushes too hard with the tape, he could open the butterfly and the screw could fall in.
1 - 8 of 8 Posts
