recently my low beam HID won't stay on.. when you turn the bike on it "fires" up for a second and then won't stay on. Would this be a problem in the ballast?
I had a similar problem and it was the actual bulb. Because it was a cheap bulb the wires actually were not soldiered well to the bulb and were not making good contact. To see if this is the case you can wiggle the wires at the bulb and see if it works intermittently.
