1 - 8 of 8 Posts
ok i changed out my stock bulbs a while back to dongtran's bulbs. i just noticed a few days ago that my low beam doesnt come on when i start my bike. i figured the housing wasnt seated right so i pushed the back of it in and the bulb came on so its ot the bulb. after pushing the housing in it would stay on a few seconds but then it would go out and i would have to push it in again. anyone ever have this problem?? i dont know how long it has been going on because i always ride with high beams on. now if i dont use high beams i have no lights at all
i had the same problem a while back check the plug wiring mine was loose
so i took it apart and rewired the plug good luck man
thanks moe, i will try that today. should i start with the housing that the bulb plugs into and work my way back?? seem like if i push the back of it the bulb actually get brighter. so i figure that would be the starting point
here is what you got to do unplug the headlight bulb
take the bulb out inspect the black housing itself
i had one with w melted prong before even though i was using
a stock bulb then inspect the plug with its wiring
keep me posted bro
damn moe i think you were right on the money with that one, took it out and looked at it and sure enough the damn thing is melted!!!! any idea how much this part will cost to replace??
i paid 5.00 to get one replaced but its your lucky day pm
me your mailing address and i will take care of you
pm sent thanks moe!!!
any time my pleasure
1 - 8 of 8 Posts
