1 - 17 of 17 Posts
Are lowers different from CA than 49 state bikes?
yes they are different simply cause CA models have the catalyic converter
the other models do not
What he said^
Damnit!!!!!
they still mount the same and everything...i think their just notched out some on the very bottom inside...
So I can buy CA ones and it will be fine on my bike??
from what I've seen yes... you'll just have a little less plastic.. there has got to be some CA guys on here to post up a picture..
I think the CA ones mount to the converter on the back portion though so you will have to fabricate a bracket to connect them to each other.
silent master
yup yup!! what he said!
Alright thanks.
I did the CA emissions removal on one of my 600RRs. On CA bikes the lowers connect in the rear to the evaporator canister mounting bracket. If you have a CA bike and want to remove all the emissions stuff you can remove the canister and replace the bracket so your lowers don't flap around. The canister itself weighs a ton so there is definitely a benefit in doing this.
I'd recommend against using CA lowers on a non CA bike because non-CA lowers connect in the rear and utilize more plastic making the tail-end of the lowers rigid. The CA lowers rely on the evaporator canister bracket to accomplish this. You can fab up a little tab (or zip tie) to connect the lowers but they will still tend to flap around.
I need 49 state lowers.
Sorry to revive such an old thread, but is it pretty easy to remove the canister? What do you do with all the hoses?
I got 49 state lowers and am having a difficult time fitting them.
Thanks guys/gals!!!
Thanks guys/gals!!!
this may help:
http://www.peterverdonedesigns.com/600RRpairsmog.htm
canister removal is easy. if you want to get into pair removal it is a little more difficult cause you have to remove the airbox. still fairly easy.
1 - 17 of 17 Posts
