1 - 15 of 15 Posts
I made my own stand thanks to 2ndtime all i had to buy was the wheels..
C.F.A. member **New Joyzeeeeeee Racer YAAAA BOY
in the pic from the back it looks like the arm is bending down under the bikes weight.
it's real stable and i think the arm is like that when i welded it. I work at a place that does truck accessories,so i coated the part that goes on my spools with bedliner so that it doesn't scratch them. I'm also getting a old motorcycle grip to put on the handle..
MotoGP NEWS Guru
Good job... that you built one. But, IMHO, that thing looks so unstable. I wouldn't put my bike on it. The tubes are way thin, and there's a reason most stands (if not all) are made of cylindrical tubes. Good job though, but I'd be reinforcing the crap out of every perpendicular joint you got there with another tube.
madrel bent tubing would def be the way to go. anybody here have access to a bender. i think there's money to be made. $$$$
Not bad for a white boy! Reinforce a little bit and you're set.
Balky Bartokomous
Hey, feel like making me some pieces so I can make my swingarm stand a spool stand? Now THAT would be rad.
1 - 15 of 15 Posts
