1 - 8 of 8 Posts
Here are some of the helpful tips that can help you out:
Change The Oil. To keep your engine running properly, you'll need to change the oil after several thousand miles —check the owner's manual to find out how often.
Replace The Air Filter.
Maintain Tire Pressure And Tread.
Change The Coolant.
Keep A Clean Chain.
Change The Coolant.
Keep A Clean Chain.
Thanks can I find this on YouTube
Proper chain slack (see manual)
Rear wheel alignment
Adjust controls (hand brake, foot brake, clutch cable, shifter, etc.)
Check all fasteners
Lube pivot points (levers, folding pegs, etc.)
Flush brakes
Clean or replace brake pins
Go get yourself a decent tool set, something with a range of spanner, sockets, allen keys etc, some screw drivers, a paddock stand and some lubricants, oil, chain lube, WD40 etc. Then get to tinkering.
Pads, oil, plugs, air filter are all good places to start. Nice and easy but strong on the maintenance check list.
1 - 8 of 8 Posts
