I've been looking at what I can do to my bike since before I bought it and was wondering what suggestions people had.
I really don't want a choppy dyno chart and all I can think to do HP wise is slip on and and power commander or dyno-jet. I'm not really interested in loosing low end power with a full system unless there is a significant weight loss with the Ti headers. same with more aggressive cams.
This is a street bike but I really don't care about global worming so I was thinking PAIR removal. How much does this help?
I was thinking about going light weight. but there aren't many posts that I found in that direction. I do realize that cutting Lbs on myself is cheeper than cutting Lbs on the bike but I can only do so much there.
The new Michelin pure tires cute 2 Lbs each, which is good for 8 Lbs if you count for gravitational mass and rotational mass.
I was thinking about Ti and Al bolts, nuts, studs, mounts, and pins. I have no idea what the weight savings is there. Pro-Bolt said 40% weight reduction on replaced bolts.
Al sprocket
Mag wheels.
Ohlins Ti/Al suspension
Are cf farings worth the price or is it mostly cosmetic? I don't want to draw attention to myself. I just want a faster bike. the stock plastic is pretty light. Everyone goes crazy over cf but it's always about the look.
fender eliminator (still deciding which one)
any other suggestions or things I should change about my plan? details that I omitted that might help me prioritize which to do first? Anything would help.
thanks
Al sprocket
Mag wheels.
thanks
