1 - 2 of 2 Posts
For some reason I'm not getting power to my fuel pump relay. I switched it with the killswitch relay and worked there so I'm sure it's not bad. My best guess is maybe a break in the wires going to it but could it be something else? My fuses are good, and the killswitch is on the run position. Only bad thing is I don't have a clock cuz I'm rebuilding the bike so I can't really test for Fi lights. Any ideas? I'd appreciate it. 05 cbr600rr
Do some searching on here as these are very common issues, but if you're rebuilding the bike check it's in neutral, clutch lever safety switch, bank angle sensor (BAS) and the kickstand switch. If any if these are bad or not in the right place electrical wise, as well as the dreaded kill switch issue, it will not prime the pump. Even if kill switch is in the run position it might still not be working.
Get back to us after you check those.
Mike
1 - 2 of 2 Posts
