my bike it idle a little below 1k rpm then it shut off when i leave it running or when i hold the clutch in when im riding it shut off. later i went to warm up the bike i adjust the throttle knob but it didnt do anything so please i need help
The idle screw is the only way to correct your problem. If the screw is broken ( a lot of people an this forum have had it break ) then you will need to fix it.
try grabbing the idle adjustment knob, while holding the cable housing. i know on my 03, it takes a few turns to get any adjustment.
Check your idle adjustment cable to see if it is actually
adjusting the. Also check your airfilter to make sure
it is not too dirty or clogged,
