1 - 3 of 3 Posts
Hi guys! i have a little bit of an issue... I went to the ground last night (left side of the bike)... at the moment the bike started, but today not. After dissembling and looking for broken parts (which couldn't found none) decided to check the battery, with the bike running the multi tester showed 12v... so my battery isn't charging. What fuses o relay should i check? The cover of the stator looks fine, maybe the hit could affect it? HELP!
:salute:
^ he already identified that the bike is not making normal voltage while running.
The regulator/rectifier is on the left side of the bike. It has a couple connections and a ground; make sure all the grounds are still in place. How badly were the fairings torn through?
1 - 3 of 3 Posts
