1 - 2 of 2 Posts
Im just fixing my cbr600 2016, the bike use to start easily and no problems on the lights. Then I change the battery and a realize that I didn’t tight it correctly, It was loose, so it’s started to make sparks in the terminal, some light fuses where burn so I replace them, but now the bike won’t start, turn signals won’t work, and I can hear the relays making weird noises, like clicking hard. Help please!!! Thank you.
Hi, just to be sure ,you installed the battery with terminals the right way round, and if it was the right way round did the sparks fly when you turned Ignition On, did you get the sweep on the Cluster ?. have you changed the 30amp Starter relay fuse and the 20amp Fi fuse, is your bike European (Immobiliser)
1 - 2 of 2 Posts
