1 - 11 of 11 Posts
My bike starts, runs doesnt over heat but if you crack into the throttle really quick it will bog out a little then rev up fine all the way to 15k. The FI light is on and the oil /coolent red LED blinks all the time. The bike has the right amount of oil in it and I checked to make sure the oil pressure sensor is hooked up which it is. anyone know how i can fix my fi light/ oil light?
Thanks.
If it's flashing, It's a code. Jot down the intervals. Slow Flash/ Fast Flash. Long Flash/ Short Flash Amount of flashes before it repeats the sequence. Then we can determine what's wrong.
blink.....blink .......................................... blink.......blink......................... repeat
code 2 or maybe code 22?
so i got everything taken apart and the vac line to the bottom of the map sensor some how came lose... i put it all back together and now everything is back to how it use to be :)
Thank you.
1 - 11 of 11 Posts
