Hey I got most of my parts in....but one problem....my FI is not turning on when I try to start my bike...
Anyone know where the fuse is...or the fuel pump relay is on our 600RR...
Thanks guys!!
Andrew....
· Premium Member
the FI fuse is in a plastic white case pop the cover open you will see the fuse the other 30amp fuse that is quite visible is the main fiuse also as per the manual look for mil light when it flashes and count those flashes evrey no has it own interpitation let me know the end result and post a reply will look up my manual and see if i can help you out good luck
