1 - 9 of 9 Posts
04 CBR - 10k miles and my horn sounds awful. It beeps once and then just sounds like its roasted. Coming home tonight from class it didn't even work at all. I do alot of highway communting and stuff. Not really sure what the problem is, the bike fired right up this morning.
Any ideas whats up?
My dash, headlights, and signals both front and rear work fine. Not really sure if its a battery or fuse problem?
The horn itself sounds like its the issue :\. Sounds awful. Just went outside to check the signals and pressed the horn and it just squeaked..
Check the wires... Wheelies and rough roads can cause a loose connection or dirty connection..
Ok I went and tugged on each of the two connectors on the horn and the bottom black wire just fell right out. So I took off it off and stripped it and touched it to the metal piece and the horn works great.
But I need to figure out how to attach it back to the metal piece since there is a piece of the wire still stuck in it?
Any ideas on how to open this little thing back up, or pick up another one?
Yep just dug through my connectors box and found one almost similar to the one that was on there. But I can't fit the little rubber protector thing over the top of it, think it should be alright?
The same thing just happened to me last week. Same wire. You can buy the spade connectors that have the rubber protector on it already. I had some from 10 yrs ago that I held on to and sure enough I ended up needing them.
Cool thanks Tripage for the quick help - everything looks like its gravy now.
Appreciate the fast responces guys.
1 - 9 of 9 Posts
