ifixed the turn signal issue ( lose connection)
now my only problem is the LOW beam not turning on...
when i flip the switch to the ON position ....i hear a very faint click in the ballast..
i do remember now. when testing the bike last nite..... when i tried flipping the sswitch ON. i heard like wire crackling they i smelt like wire burning...]
then this morning i tried agian and all i hear is a small faint click on the ballast of my HID..
the fuuses are fine also...'
do u think i burnt the ballast or something???
how strong is your battery because on mine the hids dont work if the battery is kinda weak try chargein it up then try ! ! !
nope....not the battery..........my high beam HID works fine upon startup
it must be the ballast or something blown...if u hear a sizzle of wires then a smell
wat do u think it can be??
u think the ballast or the bulb....
and dont ballast have a lifetime warranty or some thing??
im so freakin pissed!!!!!!!!!!!
Pull the ballast and see if you can see any shorts in the wires, any visibly wrong with it? T
Sizzle of wires then smell is not a good sign check the wiring connections
first hand before the headlight harness gets fried
reverse the spade connectors on the low beam.
it is reversed from the high.
I used the write up here on the board and it was a great step by step, there is even a picture of the plug on the bike that the spades go into. but for some reason it didnt work for me. I reversed the pos/neg plugs on the lowbeam side and problem fixed.
