I tried searching this but couldn't really come up with anything to answer my question. I put an '06 CBR 1000 Two Brothers Exhaust on an '07 CBR 600. Besides having to modify the pipe, is there any other complications with doing this that I will run into? Thanks and all apologies if this is a rediculous question.
You do not need to apologise cause its not a rediculous question
just make sure the exhaust flow is smooth and after you are done
go for a test ride and keep your eye on the temp gauage and as
long as the temp aint wack your bike should be alright
Alcoholic.
I think you should be alrright if you make sure you have it fit properly.
Heat shouldnt be an issue, because the system is setup for a 1000, which pumps more out then a 600. You will certainly need a dyno tune or Bazzaz system to keep it all working properly though, even more so then if you had a 600 exhaust on it.
