any advice would be appreciated i got a 03 rr but i swaped the subframe from an 05 now the midpipe doesn't line up so i figure i'll order a the 05 slip-on from arata with the midpipe but now i run into the problem with the header it's still an 03 if i swap it out with an 05 header will this work? or do i have to fabricate a sort of 03-05 header for this.
the exhaust ports are a little different but i put my 03 headers on my 05 engine and no leaks yet but thr 05 headers and everything mount up differently on the bottom
C.A.H.N founder / President
I'm no expert but it should work. If you decide to do it check the parts section here or post up in the wanted section. Great deals in there.
i just ordered one off of ebay 49 state model with low miles for 20 bucks so as long as i bracket it somehow to the 03 mounts i should be fine right? and also do the headers have gaskets?
