Hello, I recently installed some flush mount turn signals on my 05 CBR 600 and now the speedo meter cluster will not turn on properly. It will start working after 8000 RPM, but when I turn off the bike it will be the same Problem, also I installed a LED Flasher Relay to slow donw the blinker. Anyone out there know who to resolve this Problem? It realy getting on my. Please help thanks in advance.
How did you install them? Did you snip the wires on the oem blinkers so you could use the plugs from them?
Have you tried unhooking the flushmounts and relays and returning things back to stock to see if it resolves the problem? That's where I would start.
Sounds to me like you have cut the wrong wire somewhere, stick it all back to stock and start again.
Either that or the plug on the back isn't in properly, could be making intermittent contact at the higher rpm
