hi forum members,
could do with a little help and advice balancing my carbs on cbr 600rr 2005 model. i dont know the bike that well but learning by the more parts i take off the bike.
so far all body work is off the bike, radiator and down pipes. spark plugs been checked and oil change and filter. just want to balance carbs before it goes back together.
could someone give me a step by step guide with photos on how to balance my carbs.
i have tried searching for a thread but no luck. so if someone could point me in the right direction that would be grand!.
regards
kevin.
As above...
And further to that, despite common belief you can't balance the throttle bodies either...
You can balance the starter valves but unless you have made a change to the intake system such as swapping the throttle bodies for new ones this should not need to be done as it is set at factory.
