1 - 12 of 12 Posts
Can anyone help here? I can't find it on RonAyers.com. It's one of those rubber "nuts" they use to hold the lower cowl on.
I need the part number for the rubber nut that holds the rear/lower of the cowl closest to the stator cover. The bolt holds the rear of the lower and the top of the bottom cowl to the frame.
Anyone know his part number?
Were you able to see the microfiche???
Well the logical place ;) to look would be part 30 under radiator. I think that is the one you are talking about?
Yah same part. I was just showing the actual part so no confusion...
I stand corrected, it IS #30. They don't have it in stock. :(
Thanks for the help.
Are you talking about the bolt circled here
If you are looking for the piece behind that i assure you it is #15.
Looks like he got it taken care of... He was looking at the cowl on the other left;)
hahahaha.............I just order 10 of those rubber nut thingy. It can be use to mount the bodywork and windscreen.
I alway order more then I need...For just in case. They cost about $3.95 each from the local dealer in my area:banghead:
1 - 12 of 12 Posts
