Bought a downed bike and have slowly been rebuilding, got to the blinkers and have an issue. Both work as running lights. The headlights work. The low/high beam switch works. When I switch the blinker on (left or right, same result), the blinker on that side turns off completely and the cluster does not blink. I've checked the wiring several times and all looks good.
Cluster works
Switch for hi/low headlights works
Blinkers work as running lights
Blinkers turn off when asked to act as blinkers (no blinker on cluster)
Any advice? I'm stumped.
Maybe plug the rears back in, sometimes the system requires a certain amount of load to flash right - although I don't recall the RR needing this.
Did these signals come completely pre-wired? You didn't have to connect any leads yourself?
