1 - 2 of 2 Posts
Looks like the one that plugs into the sensor located in the bottom-front of the cylinder head on the left side
Not sure about the technical name though. When you run the wire from the cylinder head back behind the frame spar it will plug into that plug closer in towards the motor under the fuel tank. It won't hang out by the spar like that.
1 - 2 of 2 Posts
