1 - 11 of 11 Posts
I just bought an 04 and I have a leaking fork seal on the right side and the honda dealership is recommending I replace both even though the other one isn't leaking. Are they just trying to suck money out of me or is this really common? The bike only has 1900 miles on it so I would think the other side would still be good.
The seals do eventually wear down and the forks work in unison so it's good practice to change both.
Tell me I'm cool PLEASE!
cvlighthouse said:
I would've posted this in the above thread, but it's old and....who cares right?
Anyways, I wanted tor reply to your comment about the forks working in unison:
It won't matter much at our level, but I've heard of racers doing different settings for each leg. They say it works better based on L+R corners.
As for the original poster: Seems to me that you purchased the bike used. Do yourself a favor and get both forks done. (better if you can do it yourself) Plan on spending a little dough on anything used. You never know about the previous owners habits.
I'd get em both done. I'd do it myself mind you.
only 1900 miles. sounds like maybe someone had poor throttle control and was coming down hard from some wheelies?????
Endo's maybe??????
They shouldn't be charging you much extra to change the second seal. The labor involved for taking off one fork leg doesn't have to be repeated to take off the second. Putting the seal in the tube is a 30 minute job max.
Bike Of The Month - 09/05
I think you should replace both seals.
1 - 11 of 11 Posts
