I recently laid my bike down and broke off both OEM front turn signals, now after I fixed the bike back up my flush mounts wont even flash. I double checked the wiring and its right any other ideas to what is the problem?
You need either an LED relay or load resistors if none of them flash (front and rear), otherwise you have wired something incorrectly.
What year is your bike?
In that case you have more than likely wired it up wrong...
There are three wires going to each signal (assuming you are in the states) which ones have you wired up to?
