A friend of mine has a ZX14 that he "was" trying to sell, however some r-tard dropped the bike on the for sale lot. Now the bike won't start, the guages turn on and the lights work, but the puel pump won't prime. If anyone has any ideas to try to get this to work, please post up in here. I have to run right now, but will post up more details later.
Don't post up any "Its because it a Kawi." replies, or replies along those lines...they will be deleted.
Thanks for any help I get.
K
I'm not sure how a Kawasaki works, but i imagine that there is a bank angle sensor involved in the motor. has the attempt been made to reset it by switching the engine shut-down switch from on to off to on again while the ignition is on?
The ZX14 got tow of those sensors what a pain that is
K
save for broken relays and the such, i'm fresh out. gotta be something special.
Bypass the BAS's with a piece of wire - you are doing this to test not to ride...
Connect the fuel pump up to the battery - to test this is 'still' working.
Check its NOT in gear - "!"
Need more details....
