1 - 14 of 14 Posts
i have a 2004 cbr600rr and a few days ago this noise started, a friend of mine told me that I need to change the timing chain kit, is that necesari? or just the tensioner??
this its the noise:
in the video you can se the miles on the bike
thanks for your help
When's the last time you had your valves checked/done?
Reactions: Tuner RR
yea the chain is slapping on decel thats how you know its the tensioner has gone bad....Timing chain's rarely need to be replaced its not like a timing belt on a car where it starts to wear... as long as it properly tensioned nothing should be wrong with you chain.. i would throw a tensioner in it and with the mileage it wouldnt hurt to also have your valves checked
Reactions: Tuner RR
never :S
when i buy it y just did basic service
yea the chain is slapping on decel thats how you know its the tensioner has gone bad....Timing chain's rarely need to be replaced its not like a timing belt on a car where it starts to wear... as long as it properly tensioned nothing should be wrong with you chain.. i would throw a tensioner in it and with the mileage it would hurt to also have your valves checked
ok, so its just the tensioner.
what do I have to check about the valves?? I need to raplace them?
never :S
the valve clearance... ever hear a honda car making a tap tap tap noise at idle thats cause the valves are outta spec... same with bikes... r valves need to be set to a certain clearance... their some decent write up about how to but if your not mechanically inclined i would let your local shop take care of that
Reactions: Tuner RR
Qouted for providing great information :banger:
we need more details
-What gas are you using? Needs to be high octane.
-Spark plug/s / gap set right?
-Sounds to be turning over fine, just not getting fire.
-Is fuel pump priming when you turn the key on with the kill switch off (ready to start bike)
did you solve the problem becuase i kind have the same problem, i did change the cam chain tensioner and now it wont start just like that video i also had to recharge the battery because it drain
1 - 14 of 14 Posts
