1 - 12 of 12 Posts
Hi guys! I need some help adjusting the freeplay in my clutch and throttle cables. Exactly how and where do you mesasure the freeplay for the clutch and throttle. I know what mm the freeplay should be at, but don't know how to measure it. Thanks!
:argue:
The manual just says to adjust the freeplay to a certain mm, but I need to know how to measure it. Like at what two points are you mesauring the freeplay? I hope I don't sound stupid, but I really just don't get it.
How far it rotates from fully closed to where it begins to catch. Try turning it lightly with your fingersand you'll be able to "feel" the freeplay. Its the looseness (if that's even a word).
Clutch is the same way only with the clucth lever. The looseness from when you first pull it to where it begins to catch.
Not very technical but I hope it helps.
Thanks corner worker, that's what I was looking for. I guess there is no real acurate way to mesaure that though, like using a ruler or something?
corner worker said:
USMC 600RR said:
I know, I know....I was just trying to instigate
Don't be starting any sh#t around here. These guys hate me enough as it is.
Nobody hates you bro, you make the site well rounded :wink:
1 - 12 of 12 Posts
