:dontknow:... That's a stock OEM ECU that gave you great gains????
The 2008 ECU has to be the biggest power improvement I have ever felt on a 600. I can no longer keep the front end on the ground in 1st gear at full throttle. It cost me about $50 shipped.
yeah if you think about it the 08 doesnt have the same emmision restrictions like the 09 and up ie. timing retard at high end. so therfore you will get more power out of an older ecm. my question would be is will it adversely affect any other part of power range because i think they made a few changes to the engine but im not sure.:dontknow:... That's a stock OEM ECU that gave you great gains????
good thinkin btw
and you say the only change you had to make was the knock sensor signal wire terminal at the pcm? do the 07-08 even use the exhaust servo?
That's the reason I went with a slipon initially. I didn't want to lose the low end power. I figure the bike is already weak enough down low. Didn't want to sacrifice that.Yes, I found out from Nico, that the grey harness (B), has to have the #23 wire (colored black and yellow), moved to position 5. There is no wire in position 5. Once you do that it's just plug and play. No CEL. And lots of power. As for the exhuast flap I don't know about the 07-08 models. What I did get was one of those premade plugs with the eliminator circuit built in and covered with shrink tube. With this unit plugged in, you can remove the exhaust servo motor and cables. What I'm curious about is do you lose any low to mid-range by having the flapper always open?
I completely agree with you about the tune but a 2007-2008 ECU can actually be had cheaper than the Z-bomb/IRC, PLUS the computer doesn't think it is at 85% throttle which may limit the timing advance and hurt power across the board (can't confirm it but I would assume it). The best bet would probably be the older ECU plus a PCV or Bazzaz w/ autotune.I assume that possibly getting an 08 ECU might be cheaper, but going the route where you get the Z-Bomb and a ZFI with a tune will unlock the full potential of what you have on the bike. Just my .02
I did get an error light. The code which came up with for the knock sensor and for good reason, that seams to be the only difference in the wiring harness. If you re-pin accordingly the code will go away and the bike will run stronger than ever. I checked my plugs today and the bike is not running lean. I have been running 93 octane since doing this mod incase the difference in engine meant the 2010 model ran less timing across the board. I have done about 300 miles on the new ECU with no problems at all. Tonight I will be taking off the two brother's pipe and putting on the shortened muzzy GP style and eliminating the cat, the butterfly valve and the servo. I picked up the cap and resistors to build the eliminator as outlined in the DIY thread.wait other members here on these forums said that the 08 ecu didn't work on their 10 or 09. i can't remember, something about a error light came on and the bike ran like sh*t.
