1 - 8 of 8 Posts
Hello, just had a quick question. I am changing my pads/ going to order some custom SS Brake lines (two lines for $50), but i need to specify the banjo bolt sizes.
I did a search and all i could find is that someone used a 10x1.25 Banjo size, but i think it was for an 07 CBR. I have an 03' 600RR, anyone know what the size of the banjo bolts are supposed to be? Im assuming the master cylinder and slave cylinder use the same size? Any info would be greatly appreciated.
your avatar ....
waiting for your computer to crash are you?
your avatar ....
hahahaha good one...:crackup:
OP, id get the Clymer book for 2003-2006 CBR's...on ebay for like $25 bucks and tells you everything
Also where you gettin 2 SS lines for $50 bucks thats a good deal>?
Actually its $50 CAD, so it would be even cheaper in US... I will tell if i get an answer as to the size... :shakehand
I have the honda service manual, but they only give the torque specs for the "brake oil bolt", no thread specs given.
Actually i found it, service manual did have it i must have just glanced over it... The correct size is 10 mm bolt, 1.25 pitch.
1 - 8 of 8 Posts
