I dont mean to insult you, but are you sure the kill switch is in the run position? I ask because I`ve seen people crank the batttery dead with the kill switch off.
BTW, welcome to the boards.
The bank angle sensor is a black plastic box mounted forward of the clocks. It has a "this way up" arrow on it. If the box is not right way up, the fuel system won't work, as the bike thinks it's upside down.check that your bank angle sensor has been reinstalled correctly.
when you turn keyone does you gauge cluster get power? If not I would check the fuse under the seat by the battery.clockwork said:Ok when i turn the key to the on postion, theres no fuel pump sound. The three second shhhhh then off sound. you know what im talkin about.
my bike wont start cranks and everything.
Question is there should be one direct fuse just for the fuel pump where can i find it?
thanks
Ps HELP
