Not sure if the noise is coming from the actual clutch or another component inside the clutch cover. The best way I can describe the noise is like a metal-like noise almost like the metal clutch discs are spinning against eachother. I have replaced the clutch and it continues to make the same noise. the noise only takes place within the first 20 minutes or so after the bike is on and it only happens upon deceleration as well. Could this noise be coming from a worn clutch basket?!? I have no idea I've taken te cover off a couple times and have not noticed anything out of the ordinary. Any help is greatly appreciated... Thanks in advance...
changed the oil and havent heard it since...so nevermind i guess. still stumped on what it could have been. thanks tho..
Could have been from the cct, if the oil gets a bit to old it will get noisy.
