I installed flushmount turn signals along with an integrated turn signals on the back but it seems like my front and back right turn signals only light up when i try to signal (doesnt flash). Here's the kicker, the front and back right signals will work perfectly as long as i use the left first and then use the right (confusing enough for you?). I checked the fuses and everything is good? It was working before for a couple of months and now i get this. Is it the wiring?
D
If they're LED's or single filament bulbs, they wont light up as a running light like the stockers do.
hey guys, thanks for the replies. I checked and it doesnt have any resistors so i might have to add those for the lights to work perfectly.
you need to add in resistors. Search for flushmount turn signals. they will explain what ones and where to get them. if its a 07-08 i think you can just buy a new flasher for like $20.00 hope that helps
He's right you need the resistor to allow it to work. $20 and you can mount it inside the upper cowl.
