1 - 9 of 9 Posts
what are the normal operating temperature's for my 04 600rr?
when cruising around tonight, 45mph 4-5k rpm the temps were pretty constant around 180 (70 degree's outside temp)...then i took a short 1st gear cruise around a dealership parking lot and noticed my temp was rapidly climbing 180, 190, 198, 200, 210....so i got back on the road and let some air cool it off...the temp dropped back to 180-185...so i pull off the road, into my driveway and while the bike is idleing for 10 second's while i wait for the garage door to open, the temp says 220.
so i pull it in the garage and let it idle for another minute to see if the fan will kick on, or if the temp will go up anymore.
it stayed at 220 so i shut it off, then i turned the key back on and the fan kicked on.
after my 30 mile ride tonight, the first time ive heard the fan kick on was when i shut if off and then turned the key to the on position in my garage.
is this normal?
ive read 2 similar thread's with mixed answer's.
what are safe operating temp's for this bike?
i understand there is a temp warning light on the cluster.
i understand that the fan may have come on while i was riding, its possible i couldnt hear it with a helmet on, and a yosh rs-5 right behind me.
Cruising around about 180. In traffic 210-226. Keep in mind the fan doesn't even come on till 220 or 222. The manual states not to worry till you are in the 240-250 and around that the light will start flashing. The highest my ever got was around 229 but the air temp was over 100 and I was sitting in traffic for half an hour. Under 240 don't worry... If you hit 240 then start to worry.
220 is absolutely normal. Don't forget to use the Search function. I think this is like the 4th thread i've seen this week asking the same thing.
It gets up there especially when you stop at lights or in heavy traffic. don't be worried until it hits like 235-240
thank's guys.
today was my first day with the bike, i was just noticing the temp's on my first actual ride, and thought id ask.
i didnt search, but i looked through this forum and found 2 similar threads dealing with temp problem's...but they didnt really give me the simple answer i was looking for.
Mine kicks on at exactly 221*F every time.
Banned
70 degrees? dam, where you at?
It's hot here, so I'm constantly running in the 190's at higher speeds, 200's in the mid-range speed and 215-low 220's at a stand still.
K
as i ride, i'm usually in the mid 70's to low 80's weather i'm going 30MPH or 80 MPH. fan comes on at 103, and that's usually if i've been sitting a while.
im in illinois...normally its uber hot and humid this time of year, but yesterday night was about 70.
today is about 80.
thanks for all the info guy's.
1 - 9 of 9 Posts
