1 - 20 of 21 Posts
So I get off work this morning and on my way home I get a dam nose bleed out Of no where!! So needless to sy I'm spending my Sunday trying to get the blood cleaned off my helmet and my dam jacket... :cursin:
Ouch that sucks! Wonder what triggered that.... good luck getting blood stains out, that's a tough one to get out for sure
Now that I think about it I don't think I've ever had a nose bleed my entire life.... not that I can remember at least
if you do have frequent nose bleeds.. can be signs of a brain tumor
Guess I've had a brain tumor my whole life!
Probably just temperature/climate change. I had one a while back and just through back my head and pulled over relatively quick.
Can't imagine what how shitty your day turn out with blood splatting everywhere inside your helmet. I lucked out a few times, it bled before I went to work so I stuck 2 tissue paper up the nose to hold the bleeding and rode with my mouth opened. When I got to work, it all dried up and back to normal.
Pull all the padding out, soak it in OxyClean and laundry detergent over night, scrub it and hand wash your padding in the morning with a fresh batch of OxyClean+ detergent combo. Then for safe measure throw it in the laundry machine with a batch of your clothing, let it air dry, all should be fine.
I sneezed one time which resulted in a instant nose bleed... My visor nar.. Had to pull over and plug my nose then ride home with my visor up lol only thing i had to clean was the chin curtin and everything infront of my face. Just soak it in oxy clean and cold water for a hour or two. Should be.good as new.
To get blood out use hydrogen peroxide..... takes it right out and shouldn't damage your clothes. I've done it countless times when I used to be an emt and people would bleed out on their clothes.
Sent from my DROID RAZR using Motorcycle.com Free App
1 - 20 of 21 Posts
