Simple question:
Would a full fairing set (upper, tank cover, ram air covers, mids, lowers, and tail)off an o5 bolt right up to an o3/o4? From just a glance I can tell the tails are a bit different but is anything else? Even if they are a little different, will all the o5 fairings bolt up to a o3/o4 frame, subframe, fairing stay, headlight, etc with out a problem? Thanx a lot!
APEX
these parts that will not bolt up without other parts are
upper you would need the 05 ram air assembley , windscreen
tail you would need the 05 subframe,05 seat frame guards ( triangle pieces below the seat )05 passeneger pegs ( if you take passengers for rides )05 battery tray
front fender wont fit the rest of the fairings are identical so they will fit
without any problems
