1 - 2 of 2 Posts
I need to change the color of this red fire engine here...
to look like this fire engine here...
Can any of your expert help me out?
Here is a quick fix i guess. Use the eyedrop tool and click anywhere in the red part of the fire engine. Drop down the "Select" menu bar and go to color range. Make sure "Image" is checked instead of "Selection". Where it says "Selection Preview" at the bottom of the window, pull it down and selct "White Matte" and then hit OK. This will show you what you are going to be changing. Now just go to the "Image" pull down menu and go to "Adjustments" and mess around with the hues, saturations etc until you have something close. There is another way where you could get it pretty much exact but that takes longer. Hope this helps
1 - 2 of 2 Posts
