1 - 20 of 20 Posts
So this has bothered me since I fitted it in 2010 😂, but the Scorpion end can on my RR4 has never sat in the centre, and I wonder if any of you have seen this before and can think of a solution please?
Or do I just need to take it all off and try to bend it to fit more centrally? 🤔
It's the correct model for the year, and everything is bolted on correctly, but it seems the midpipe fouls under the tail and stops the end can sitting centrally... So it looks wonky.
Anyone seen this before?
Apologies for the dirty bike and garage 😆
Automotive tire Motor vehicle Automotive lighting Tire Blue
Motor vehicle Automotive tire Automotive design Engineering Gas
Automotive tire Motor vehicle Vehicle Automotive lighting Blue
Thanks!
The rubber grommets at the back tail end allow movement. But you cannot adjust to a fixed spot with hardware there. It’s honestly kind of dumb. Vibrations move it around and it settles wherever it settles to. Good luck let us know if you find a solution and how. (It’s good for OEM exhaust… but bad for aftermarket).
Discussion Starter · #5 ·
Yeah, that would drive me crazy. I'd suggest you loosen all the bolts from the header back and give it a little love tap, tap, shove. If that doesn't work get a ball peen hammer. Something will give. :LOL:
It has annoyed me for.. well.. about 12yrs :D but for some reason am only now thinking about fixing it!
Are you sure you have the correct model for your bike? This is my Leo Vince
Yours certainly looks to have more room under the tail for the pipe... I don't have the box anymore, but it was advertised as an 03-04 600RR end can.
I did look at buying a replacement, but exhaust prices have more than doubled in the past 10yrs 😳
It was just £150 for titanium when i bought it, and now they're closer to £400 !
Will get another pic of the underside tomorrow, but all the bolts seem to be lined up properly,...
Maybe will whip the tail fairing off, and see if it can wriggle further, but it may be pretty rusted in place 😆
Discussion Starter · #6 ·
Yeah, i don't know how much chance for re-positioning there is. The hanger does allow some sideways movement, but don't think it can hold it in a new position.
Interestingly the exhaust never had any fitment for springs like you usually see on bike exhausts, but never had any issues with leaks due to natural movement.
· Super Moderator
I'm not sure how yours is mounted but my '04 has a single hanger around the slip on and another mounted point on the right side. The only rubber I can see is around the can to protect it and at the bolt for the hanger. Those are meant for vibration isolation and not adjust-ability of the exhaust pipe.
There are a couple of Yoshi's and a Micron CF on eBay right now for pretty cheap....
Discussion Starter · #8 ·
I just have the standard 2 mounting points, bolt on the right and the hangar also.
Seems I'm not quite fouling on the heat shield on the left, but it's close. 🤔
Will see if I can take the tail off tomorrow, as it doesn't seem to move at all.
(bike really needs a wash too! 😂)
Hood Automotive tire Automotive lighting Blue Motor vehicle
Leg Motor vehicle Automotive tire Bicycle Wood
Blue Wood Automotive tire Motor vehicle Electric blue
Sadly no decent named exhausts in the UK below £250
· Super Moderator
I think most aftermarket silencers don’t sit central.
Pretty sure the one on my race bike doesn’t and that’s an Akrapovic full titanium race system.
I’ll check in the morning as for some reason I can’t remember! Lol
I think you're right. I remember most everyone complaining about crooked tail pipes. The Italians (Leo Vince) are one of the few who got it right.
Discussion Starter · #13 ·
Interesting, thanks Ruby!
Typical Italians getting it right! :D
Looks like mid-pipe is not the correct bend pattern to clear the EGCV box.
It's got unnecessary bends in odd places and bend into can is not correct....maybe for 03-06?
Yeah, it does look different to the Leo Vince above, but seems correct up to the right mounting point.
Mine's 2004, so that should be correct... or did you mean a later year?
I think 05-06 they changed the RR slightly, maybe it's meant for a newer model.
Discussion Starter · #15 ·
That's what I first thought but when I went back and looked at your pics again you can clearly see "01/04" stamped on the end. I think they just rushed the R&D to get it to the market and then revised it later.
Well spotted.
Quite possibly. Scorpion don't do that shape anymore, so maybe they decided to change afterwards and make sure it fitted!
If I can't fix it with some washers to push it left a bit more, I may consider buying a slightly lesser known Delkevic exhaust that definitely fits, and then selling this Scorpion one.
Judging by going rates for branded exhausts, I could probably undercut them all and still sell for more than what I originally paid 🤔🤞🏻
· Super Moderator
Alternatively you could see what a local welder might charge to cut out the offsets and weld in a new piece of pipe. That way you can at least have a chance at maybe bartering to reduce the cost. Especially if you can do most of the cutting and have everything ready for them to simply weld up.
I wanted to ask earlier but forgot. It looks like it sticks out too far past the brake light. So you could also shorten it.
Note that muffler hanger is a pivot point around vertical axis. Where rear/tip of muffler ends up has to do with where inlet/front-end is located.
To move muffler tip/outlet to left <--, you need to move front/inlet of muffler to right -->. Disconnect everything and mount just muffler on hanger and wiggle front/inlet around and you'll see how rear reacts.
Easiest way to fix is to move front of muffler to right by removal of lateral section from inlet pipe. This will also solve your clearance issue with heatshield. If this is really titanium, welder should be familiar with material and have necessary equipment to flush backside of weld with argon as he welds.
2015 ZX-14R 2009 CBR 600RR
I had a similar problem when I cut out my cat and my Two Brothers slip on wasn't centered anymore. Required a lot of adjusting / twisting of the mid pipe where it connects to the header end and the slip on end. BTW you don't need any heat shields, pipe just doesn't get that hot. No one I know has ever had a problem without heat shields.
Discussion Starter · #20 ·
Thanks for that! Yeah, i figured the inlet would need to go right to move the rear left. When I get some spare time I'll certainly try to undo it all and rejiggle.
As far as I'm aware the end can is titanium... i'm not so sure about the midpipe, but hopefully it can be rectified before welding is needed.
Yup. The full titanium race system on my 2005 doesn’t exit straight at the can.
Hmm, that's interesting but also very annoying too!
Frustrating!
Good to know about the heatshield tho!
1 - 20 of 20 Posts
