1 - 3 of 3 Posts
Track bike leaking oil from the clutch cover. I've never seen this before.
Source of leak is the clutch lever that the clutch cable connects to.
Do I need a new clutch cover or can I replace some seal or something inside the lever mechanism that the cable connects to? :ponder:
Picture of Leak!
Picture of my bike just for fun:
There is a seal in that spot that can/does go bad so it's a cheap fix; should be a bushing as well but look at the fiche to be sure. However I'd also take a good look at the cover in that area as I've seen other bikes develop cracks with can lead to the leaks; there is a lot of pressure at that area when you pull the clutch in. If the bike has had an impact in that area it can cause issues as well.
Mike
1 - 3 of 3 Posts
