1 - 8 of 8 Posts
Pic didnt show up..
Could be from the oil pressure switch (has the black rubber boot). I noticed the same on my 03 and it was coming from the pressure switch. Ordered a new pressure switch, o-ring, and sealing bolt and problem was solved.
Take the toolbox off and see just where it is coming from. Its just that 10mm bolt you see there next to your finger. Toolbox has a nub that sticks inside a framehole. My guess is its coming from the valve cover gasket, or CCT gasket if someone tinkered with it.
1 - 8 of 8 Posts
