Hi I’m new to bikes and needing help. I have a 2016 cbr600rr. When I turn the bike on (engine not running), all lights turn on and go off. The only one that stays on is the oil pressure. I have check oil levels and they are fine. When I turn the engine on as soon as I release the starter button the bike shuts off. I press the starter button again and then the bike will turn on and oil pressure light turns off. Anyone have any idea what could be wrong?
Hi and welcome!
That's correct operation of oil-pressure light (not oil level).
Oil-preasure light stays on because engine isn't spinning, oil pump isn't spinning and there's no oil-pressure.
Oil-pressure lights turns off because engine is spinning, oil-pump is spinning and there's oil-pressure.
Oil level is something completely different. There is no oil-level sensor in engine, so you should check oil-level on sight-glass on side of engine before every ride.
Discussion Starter · #3 ·
Hi and welcome!
Thanks I guess I may be asking the wrong question. I guess Im trying to find out why when I try to start my bike and the oil pressure light is on my bike won’t stay on when I release the starter. ( as soon as I release the starter after I hear the bike has started it shuts off and oil pressure light remains on) I have to press and hold the starter a few times to get the bike to stay on. Once it stays on the oil presser indicator turns off. I have had the bike for a year and it just started doing this.
OK, let's completely remove oil-pressure light from this issue because it's working properly.
Your problem is bike doesn't stay running when you let off start-button. This is 5-minute fix with multimeter and measuring voltage at various parts of wiring harness. Do you have multimeter and know how to use it to measure voltage and resistance?
