1 - 15 of 15 Posts
Bought new headlight, new fairings ( accident last season).
put all back together, along with integrated tail light, led signals,
new battery,, but then it didn't start, DIDN'T EVEN CRANK.
Check all cables, BAS, all seemed ok so my broth and I decided
to bypass the starter relay and it cranked. changed the stater
relay, not it cranks but does not start. No fuse problems I checked them all.
yes i already checked kill switch.
help me please
so the starter motor cranks but the bike doesn't start ?
Does n't start
Yes you're right, it cranks, but dont's start.
Also, someone asked me if the fuel pump is priming....how do I know that?
Gauges / tach is all ok, lights and signals ok,
Do you hear the fuel pump making a noise ?
Easy way to find out is:
1. With the KILL switch OFF, turn ignition to ON, watch dash lights & listen - DO NOT TRY TO START.
2. turn ignition OFF
3. Turn KILL switch ON, Turn ignition ON watch dash lights & listen - DO NOT TRY TO START.
Does it make the same noises?
Once you turn the kill switch to run with the ignition on, you should hear the fuel pump prime itself. It is not quiet but really not too loud. But you should know if it is priming. Good luck with the fix
K
Fuel pump makes a Reeeeeeeeeeeeeeeeeeeeeeee sound as soon as the kill switch is flipped to on and the ignition is on.
if it doesn't, check your fuel cut off relay for proper operation.
Update. I thought starter relay was deffective, actually not.
Why? I was bypassing the relay to crank it and it was cranking.
So i guessed that the starter relay was bad. I put the new one
but still nothing, so if I bypass the starter relay it cranks,
but no sound of the fuel pump priming...so
next step how do I check that?
Discussion Starter #13 (Edited)
Sorry, I meant is it normal third eye does NOT turn on?
@ Dving, so far no sound of fuel pump...only a click from the gauge
(guess is the needle when it falls back to zero)
@ knight, bas was already mounted with lights when I bought them,
and it looked exactly like the picture.
guys
THANKS!!!!!!!!!!!!!!!
While lookinng for the fuel relay in the manual (didn't want to sound like a donkey and ask you where it was located), i read that there's a bunch of fuses on left middle fairing, and actually one was blowned up. battery was drained but was able to cranck and run for not even 2 seconds but at least started, now have to recharge de battery it's dead now.
thanks will keep you updated but looks great for now.
1 - 15 of 15 Posts
