1 - 14 of 14 Posts
I have a black 2006 cbr600rr with flush mount signals, integrated signals and rt-1 jardine pipe, bike worked for 4 months prior to incident with all the mods. i just laid it down 2 weeks ago. when i laid it down it, it slid on the right side ( side of the clutch casing and rear brake set) it started right after the crash and i drove it a couple hundred yards to a parking lot. i replaced the rear right set, and all the fairings are removed, the new fairings are ready to be put on but the bike wont turn over. its getting power to the lights and everything but the killswitch doesnt turn on the fuel pump any more. it just shows a red oil light and the ignition runs but no spark. I checked the BAS and all the fuses, but both were fine, im lost and need help. soo please HELP!!!
G
With the key turned to the ON Position, cycle the engine kill switch from on, to off, then on again. switch the key off then back on.
should work. This is the procedure to reset the BAS that most likely tripped when you "Laid it down".
Discussion Starter · #8 ·
Well i was reading the forums about the BAS at work and when I came home I checked it to see if that was my problem, Only I couldnt exactly remember the diagram. I know Im going to feel like a tool for this but I cant find the one forum with a picture diagram of how the BAS is supposed to be connected correctly. why am im so dumb with something so simple?
+1...........also, when you turn the key on does your oil pressure light blink.....if so the bike is giving you a code to something that is wrong. Let me know how many times it blinks after you turn the bike on (if at all) and I will tell you what it is indicating is wrong.
1 - 14 of 14 Posts
