you might be low on coolant in the radiator itself. if this is the case you'd have a very hot running bike. pull the radiator cap and see if the coolant is right up to the very top of the filler, where its supposed to be.
then, after you add the coolant to top it off and make sure the overflow bottle is topped off too-to the max fill line. then with the radiator cap off, run the bike till it gets to operating temp (at least 220F on the RR, probably same for you). your fan should kick on at this point-listen to make sure its still operating. if not, check your fuse. and spin the fan (when engine is off) to check it still spins freely.
once up to temp (this makes sure the thermostat is open letting coolant flow through the whole system) then blip the throttle quick and hard a few times. this is 'burping' the air out of the system. even if you are topped off with coolant an air gap will allow the engine to really overheat.
also check your radiatior cap to make sure its holding pressure-unlikely given the sequence of events you described but if they get old and lose their pressure they will allow the engine to overheat too.
hope this helps.
