1 - 8 of 8 Posts
06 cbr motor with 2500 miles on it.
pair mod
bmc race filter
leo vince slip on
DIY short velocity stacks
thermostat removed
dyno tune
using liquid performance racing coolant
here is the story. in september of last year i did all the mods and had the bike tuned. now today i noticed that my bike was creeping up to 230 degrees. the weather here was pretty humid (about 60 percent) and the temps where in the upper 80s and low 90s. i was riding around the city (philadelphia) doing errands and the temp would go down while i was moving, and then when i stopped at a few lights in a row it would slowly climb to 220, the fan would kick on, but it would keep climbing very slowly. highest i saw on the temp reading was 232..
now i know that when i'm not in the city, and i'm riding out in the country the temps stay in the 180s since i'm moving. and if i start the bike cold and let it go all the way to 220 the fan kicks on, and the temp goes back down pretty quickly.
so should i be worried that after riding for about an hour in the city on a hot day the temp goes above 220 even with the fan? is this an early sign of overheating issues?
thanks everyone
sorry lol...just read the sticky, apparently anything around 230-249 is still okay. 250 and up is overheating?
still wondering if i should check anything out tho? thanks again
pair mod
bmc race filter
leo vince slip on
thermostat removed
dyno tune
thanks everyone
sounds like you have nothing to worry about sir. everything you've stated seems dead on to what 1,000,000,000 other members including me experience while riding on the open road :shakehand
quick question though. why did you remove the thermostat? there cant be any benefits to it is there?
^ one less thing to go wrong, the only real downfall is the time it takes for the bike to heat up... it can also cause issues with running temp in cold climates...
exactly what nico said. i took it out so i wouldn't have to worry about it getting stuck.
and yes its true that it does take a little longer to warm up, but i dont mind. I just do a full pre-ride inspection while the bike warms up to about 140ish and then i take it for a quick spin around the block to make sure everything rides okay. by the end of that its reached 180 atleast and i go in to grab my gear and head out for my ride. works well for me.
as for the temp issues in cold weather. i think it would have to be pretty cold since i've been out when it was around 30-40 degrees and the bike ran just fine.
Yep, it does have to be pretty cold.... not likely to happen on a bike cause once it is down that far you probably wont be riding but in a car its a different story.
1 - 8 of 8 Posts
