1 - 2 of 2 Posts
Hi all, if you keep the oxygen sensor in the exhaust system, this should keep the mixture right even if you fit and end can and an after market air filter, is that correct
no. use the search.....
o2 sensor is for emissions compliance only.
If you install pc5 or equal, the o2 sensor is used for A/F control.
these ecu's are not capable of realtime a/f control.
1 - 2 of 2 Posts
