1 - 10 of 10 Posts
Hi Fellas,
I recently performed a thorough maintenance to my, new to me, 09 600rr. Refreshed the oil, coolant, brake fluid, air filter, and plugs. When I removed the lower fairings I had 2 pieces fall to the ground, see pic. I spent quite a bit of time looking to see where they might have come loose from but I was not able to spot it. In any case, I am posting here to see if any of you have seen this little bracket on your bike. It is shaped a certain way as part of the cable management.
It is an ABS bike, so it has additional wiring, hoses and lines for the C-ABS system. Anyway, any help would be appreciated and thanks in advance.
· Super Moderator
Did you go to any bike meets lately?
· Administrator
The PO may have lost it at one time and didn't think the check the lower fairing. He may have gone and replaced it and now you've found the original part. That my be why you can't find the missing place it came from. It's already been replaced.
2009 CBR600RR
Looks like it could be from whats used to hold the fuel/vapor lines in place. My best guess is it's the one on the bottom of the fuel tank (not pictured), or its possible to be the one like in the picture.
Motor vehicle Automotive tire Automotive fuel system Automotive design Automotive exterior
Discussion Starter · #9 ·
That one kind of looks like it is shaped the same. I'll definitely check for that one.
Thanks!
1 - 10 of 10 Posts
