1 - 11 of 11 Posts
Deeze
Does anyone have pictures of a PCIII. Specifically the TPS sensor connector. Trying to see the wires that go to it.
Deeze
no that doesn't help, they don't show any pictures of how it should look on the PCIII itself. I'm not looking for how to install it. I already installed it. The connector was cut off and mine has 2 wires going from the PCIII, but Dynojet only shows 1 wire getting spliced in. Looking for examples to compare.
Deeze
that helps a little, I'm just wondering how many wires go into the TPS sensor connector off of the PCIII. Cant see it in the pics, and that's an 05.
Its not that hard to find. Its on the left side of the block right behind the frame. You have to remove your fairing and use a couple of fingers to reach it behind the frame. Its a plug that looks exactly like the one on the PCIII
Deeze
first off thanks for the replies,
Maybe I'm not explaining what I need right. I'm not asking how to install it. I already did that. Mine doesn't have a connector that goes to the TPS sensor. There are 3 wires on the bike for the sensor. My pcIII has 2 wires that go to the sensor, but the instructions just show 1 that gets spliced in. I'm wondering how many wires go from the PCIII to the TPS sensor.
Deeze
I had this on my bike and custom mapped for a year so I know it works. I have two wires, one is connected to the red/yellow wire on the tps the other goes to the green/yellow. Not sure what color they are since i rewired it. I just can't seem to find any instructions that show two wires.
1 - 11 of 11 Posts
